Glitch
- Points
- 228
- 4x4-Mega
- BigRock 4x4
- Outcast 4s
- Senton Mega
- Vorteks
Hi all!
Just wanted a few opinions on my plan to stop motor mount bending on my vorteks.
1. Replace stock plate (and mount, whatever) with this- the new thicker Arrma plate. https://jennysrc.com/collections/ou...uminum-motor-mount-set-heatsink-fan-ara4408v2
2. Get a couple 36mm O rings to strap around either end of the heat sink to prevent motor moving down.
3. Attach those screws that many have had success with into the chassis
4. Put a small piece of curved foam under the end of the motor to effectively do the same thing as the o rings
Does this sound like it’ll work? Could I just use the stock plate or a cheap Amazon plate instead of getting the new Arrma one?
Thanks!
Thanks!
