I would definitely consider taking it apart (if you're comfortable with it) first before I gained confidence in the lipo health. That's just me. Pics are slightly blurry so it's a little hard to tell details. If I didn't feel comfortable though, I'd probably chuck it.
Side note: I've been considering those HRB premiums. How do you like them?
Rewrap it but keep an eye on it.
That's a tough call... be very careful when charging and storing.
What does your charger have to say on the subject? If all the numbers are good I would give it a good duct tape wrap and call it good. Ugly doesn't always mean bad.
I mean just go through the settings, cell voltage, resistance, and so on. If all the numbers are good then your battery is just ugly. I can live with ugly. I would make sure it's healthy before you try charging it. If it has a short in it it will show up on your charger's voltage meters.
Well I hooked it up and the charger wont touch it so its trashed. It is what it is. Thanks though! Much appreciated.
Yessir! Its goin goin gone. Ill order another. Thanks for your thoughts!Then your charger has given it's opinion. Thumbs down!
