soloudsmith
So I’m looking to Truggified typhon 3s 4x4 blx. ive done Some research but most things I find are on the 6s. What parts are compatible woth the 3s that I can use?
Is there anything else I can do for it to sit a little wider?You only need 17mm truggy wheels. Maybe gear down the pinion if you go with heavier or larger tires.
I wouldn’t advise going wider. It’s going to handle like crap. A square wheelbase will have awful performance. You won’t be able to keep it going straight. It will just do donuts.Is there anything else I can do for it to sit a little wider?
