Pageracing
- Mojave
- Typhon 6s
Just went ahead and did stainless screws on my badlands setup. Now running them on my talion. Nice light setup that has awesome traction.
Here’s the exact setup I’m running.Which Offset size 17mm hex adapters do you go with??
I do the stainless screws on any wheel that uses screws. Definitely helps to break up all the black on the tires and wheels. For those you posted you just need 24 m3x12 stainless screws.Yeah,the stainless bolts REALLY added contrast detail. I might copy it because that looks better than this:View attachment 128639
ThanksI do the stainless screws on any wheel that uses screws. Definitely helps to break up all the black on the tires and wheels. For those you posted you just need 24 m3x12 stainless screws.
Yeah pretty similar tread for sure. I had these already because they are maxx specific offset (I have two maxxes) so I’ve been swapping between the katars and these badlands.those tires look like an expensive set of dboots backflips
that makes senseYeah pretty similar tread for sure. I had these already because they are maxx specific offset (I have two maxxes) so I’ve been swapping between the katars and these badlands.
I will. So far so good. And I do jumps and backflips nonstop with the Arrma and my maxxes. No issues yet.Let us know how the plastic wheel hubs hold up. I've read the 17mm versions like to crack when jumping much.
6S and 4S or just 4S trucks?I will. So far so good. And I do jumps and backflips nonstop with the Arrma and my maxxes. No issues yet.
