Typhon 3s motor fan died, overheated engine?!
Solitary
New Member
Hello.
Recently bought a Typhon 3s.
Was running on the track today and on the way home i popped in a new battery and did some maxed out runs for a whole battery.
Was about to go home and i noticed the motor fan was not running. The motor was very very hot to touch.
Is it screwed?
Not necessarily. Stock fans can easily give out or just get the smallest particle in it to stop running. Happened to me. Took it off and cleaned it out. Working fine again. Let your motor cool. Try it again but get that fan fixed asap or replaced.
I thought the typhon had a thermistor interlock should the motor or ESC get over heated until it cools down, maybe I'm wrong?
The esc does at 257? Degrees..
Motor does not have anything..
