yomamma219
- Typhon 6s
So I have had my typhon for about a week now and figured I would jot down some thoughts for anyone else that might be looking at getting one. For reference my previous RC experience is an ECX torment, Exceed RC Drift king, and my first was a 2.5 Tmaxx. So my initial thought is that this thing is way way faster than anything I have had before and I am only running on 4s lipo. I turned my punch down to 3 on the car after a few days to try and take some of the touchy-ness out of the throttle control. Speaking of throttle control, the biggest disappointment so far on this car has been the radio system. I am getting intermittent instances of the car "holding last input" (I'll call it) for brief moments. If I was turning to the left it will hold that turn for an extra second or two after I've turned back to the right, same with acceleration inputs; therefore I already have an aftermarket radio on the way (Radiolink RC4GS combo), since I could not imagine having the confidence to run on 6s with this issue present. A few other people have complained about similar symptoms and one person said they had it covered under warranty and the replacement was fine, so I do intend to contact customer service about the issue just haven't gotten around to it yet. For reference my ECX torment uses the same radio system, I believe, and the same symptoms occur, though with significantly less frequency, or at least its less noticeable. Other than that it has been a blast to drive. i have bumped it into a few things and taken it off the biggest jumps I have ever taken an RC off (4 feet or so ) and have not had one mechanical issue with it. The factory tires seem to have worn down a bit faster than I would have thought (about six 4s-52000mah packs and they are at 10% treads on the front and 25% tread on the rear) but I attribute that to how much sliding I am doing with the car on asphalt, combined with how heavy it is. For comparison I would guess it doesn't weigh much less than my T-maxx.
Since my tires wore down so fast, new ones were the first upgrade I purchased. I bought the Duratrax Bandito. To be honest I was a bit disappointing in my purchase because they are TOO grippy for what I was looking for. I can no longer do the nice power slides and flicks with the car on pavement, and unless I lower the ride height basically all the way, it will traction roll like crazy. They do make the car handle like its on rails and I can really feel differences in how I adjust the front/back ride height with them, which has been fun in its own way but is not what I am looking for since I am solely bashing this thing. Because they are gripping instead of slipping they don't seem like they are wearing at all after 2 packs. I have for the time being taken them back off but plan to give them another try once I am running 6s or put the speed pinion in. If anyone can recommend a longer lasting tire setup with low on road grip I would appreciate it, but my search has primarily turned up Duratrax Lockouts and Proline Badlands. I am still holding out though as I would prefer to not spend $50+ a month on tires for this car. Plus I am thinking I am going to put in the kraton hubs, axles and hexes on the car so that I have more options since that seems to allow for the "2.8" wheel size to fit without rubbing. What I haven't been able to figure out is if I would be able to fit a MT type wheel on the typhon without the kraton arms, which is what I would really like to do. It looks like doing only the hub setup extends the wheelbase at the front by about 14mm at each corner (total 28mm wider). For reference to better understand the whole "truggified" setup I made my own partial parts spreadsheet which is listed by part type instead of part number so that I could see what the typhon/talian/kraton all were using and more easily identify the differences. I am not very good at finding parts cheaply so I have not purchased the kraton hub setup until I am sure it will do what I want (MT wheels/tires) since it seems there are hub extenders that will allow 2.8 tires to fit are are a cheaper solution. Side effect of my spread sheet is that I now see that if you own only a Typhon and Kraton, you can essentially create a talion and outcast with the parts on hand, so its basically 4 cars for the price of 2! It would be awesome if arrma created a tool where you could customize the various blx cars with other cars' parts to see what what needed for which conversions or just make some sort of Frankenstein machine. Or just a sticked thread that showed some of the more common conversions and listed the parts required and what benefit the conversions gave you.
Since running and jumping on pavement was beating up the metal chassis and the differential bumps more than I wanted I already have installed the RPM rear skid plate which I am please with but haven't had a chance to beat on yet and am waiting for delivery of the T-bone racing front bumper (acts as a front skid plate also) and rear mud guards which I am hoping will keep grass and sticks out of the rear axle area which is where they seems to collect the most. I am also hoping to get a second body for the car for cheap that I can cut up and do some ventilation type modifications to. Finally of course someday I will upgrade to the big old 6s lipos but I want to get the car armored and running flawlessly first.
Lastly, just wanted to say with how happy I am with its on/off road performance (in reference to stock tires) as a "basher". In dirt and gravel it slides around wonderfully and is very controllable. This is probably my favorite surface type to drive it on. In low or thing grass/weeds it grips quite nicely but I can still get a bit of sliding going using the throttle, but have to be very careful of rolling it. I set the ride height up pretty high to try to help with clearances and soaking up bumps which it does beautifully. In thicker/tall grass/weeds and underbrush it definitely bottoms out and and just isn't tall enough or have enough tire to ride over. On pavement is where I do most of my driving and love it. it will slip and slide around, and do 180 flicks for days as well as some alright power slides. The awd does seem to prevent prolonged pavement drifts though since instead of spinning the rear tires it seems to transfer the power to the front and pull itself out of the drift. I think this could be remedied with thicker diff fluids in all diffs and some suspension tweaking. I prefer dirt/gravel over pavement because the lower traction seems to allow more drifting and sliding with the car.
TL;DR:
Thoughts:
Typhon is FAST compared to my Ecx torment,
Typhon is pretty big and heavy but seems durable.
Typhon is a blast to drive on or off road.
Stock wheels don't last that long sliding around on pavement, even with just 4s. Guesstimating total about 15-20 runs and they will wear through.
Stock radio in the V4 models (Spektrum Brand) is not what I would consider sufficient for a car that can hit 70mph. Primarily since I get way too many interruptions which at 70mph could easily result in a destroyed car
The parts Compatibility with the other Arrma BLX models is something that I think is a bit undervalued on these cars.
Questions:
Anyone have any budget tire/wheel combos that are durable and low traction on pavement? Current research indicates Duratrax Lockups or Proline Badline buggy, but I would prefer something for about $40 max/set.
If I swap to kraton hub, axles and hexes onto stock typhon arms, can I fit MT wheels (more specifically Outcast wheels)? Or is this mod more-so just to fit 2.8 wheels without extenders?
Sorry if this is in the wrong spot and for the excessive rambling. Got a bit bored today.
TL;DR:
Thoughts:
Questions:
