feedle
- Senton 3s
- Typhon 6s
Hello, I'm having an issue with my Typhon 6s. I just ruined my second castle 1515 2200kv motor (rotors finally came back in stock, so I ordered a new one this time rather than a whole motor).
Anyway, my motor suddenly got hot (it has always ran barely warm to the touch after a hard bashing session) and reeked. Presumably, it hit the temp cutoff on the ESC since it was beeping and well, it wouldn't attempt to move if I hit the throttle. The motor became harder to turn though so I knew I cooked the rotor again. Unfortunately I don't have data logs from when it happened. Temp cutoff for the first time it happened was 170f and the second time was I believe 150 or 140. I'll attach photos of the rotors.
Basically, my question is why does this just suddenly happen? First time it happened was in grass bashing around, second time in a parking lot doing speed runs.
My esc is a Castle Mamba Monster X and I've got a Hoovo 6s lipo. 17t pinion, stock spur. If you need more info, ask away.
Top is the first time it happened. These are two different motors as well, rotors weren't in stock when it happened the first time.
rip motor #1, Nov 28 - Jan 12
rip motor #2, Jan 12 - Mar 19
