Probably the mount, the servo is tallerYou might need a new servo mount because of the torque but besides that it’s plug and play
And you can’t program end points on the stock radio I believe
Ok thanks for that info. Im sure the mount will specify for felony and what servo it can hold?You might need a new servo mount because of the torque but besides that it’s plug and play
The mount on the PP website will work with the Felony & the PP servo.Cool thanks for
Like this one?? https://www.perfectpassrc.com/products/aluminum-servo-mount-for-rc-carsThe mount on the PP website will work with the Felony & the PP servo.
Yep. Should do it. I think it says fits the PP monster in that description. You may need a 25t horn also.
yea it says it... read everything in the description to make sure lol n the pp monster comes with the 25t horn. so all covered there. Thanks a ton really appreciate the helpYep. Should do it. I think it says fits the PP monster in that description. You may need a 25t horn also.
Cool. You're welcome!yea it says it... read everything in the description to make sure lol n the pp monster comes with the 25t horn. so all covered there. Thanks a ton really appreciate the help
Sure you can. Page 14 of the manual.And you can’t program end points on the stock radio I believe
lol nice n thanks... just got watching a video from you tube saying not a good idea to do it lol
I’ve done it plenty of times. Just make sure to recalibrate AVC after making the endpoint adjustments.lol nice n thanks... just got watching a video from you tube saying not a good idea to do it lol
ok sweet... I will give it a shot when I the servo and mount arrive. I guessing the book tells you how to recalibrate the AVC too? As I will give it another read over.I’ve done it plenty of times. Just make sure to recalibrate AVC after making the endpoint adjustments.
Yes it sure doesI guessing the book tells you how to recalibrate the AVC too?
Awesome and thank you for the info!!Yes it sure does
Heads up, PP servo is ludicrous overkill for the Felony and is quite an amp hungry thing. You won't get full power from the servo on the stock BEC and could even brown out the receiver on hard turns. I'd recommend picking up a glitch buster for the receiver to be safe. When I upgraded my infraction servo I lost signal during hard turns until I added a glitch buster. Eventually I just started running receiver packs to make sure I was getting full servo power, but you could also do an external BEC instead.Looking to get the perfect pass monster servo for my Felony 6s. Do I need anything special with it or can I just plug and play it with the reg. calibration end points??
I ran into this with a Reefs Raw 500 servo, was browning out the castle esc. Needed an external BECHeads up, PP servo is ludicrous overkill for the Felony and is quite an amp hungry thing. You won't get full power from the servo on the stock BEC and could even brown out the receiver on hard turns. I'd recommend picking up a glitch buster for the receiver to be safe. When I upgraded my infraction servo I lost signal during hard turns until I added a glitch buster. Eventually I just started running receiver packs to make sure I was getting full servo power, but you could also do an external BEC instead.
First thanks for the heads up. now lost with the Bec and glitch buster! lol Bec is for? N I assume the glitch buster plugs into the receiver to protect it??Heads up, PP servo is ludicrous overkill for the Felony and is quite an amp hungry thing. You won't get full power from the servo on the stock BEC and could even brown out the receiver on hard turns. I'd recommend picking up a glitch buster for the receiver to be safe. When I upgraded my infraction servo I lost signal during hard turns until I added a glitch buster. Eventually I just started running receiver packs to make sure I was getting full servo power, but you could also do an external BEC instead.
I will certainly try those settings as for now I use my felony for drifting n light speed runs but will be looking to amp it to do 120+ down the roadI ran into this with a Reefs Raw 500 servo, was browning out the castle esc. Needed an external BEC
@Zental I believe the SR6110AT receiver is similar to the SR6200A I run in my Typhon. Excellent settings were 50% steering and 0% throttle. It will help correct the steering without fighting you and won't cut the throttle when it's correcting. Use-Case of your Felony may be different than my Typhon (street drifting vs bashing) but worth a try
Also any recommended glitch buster or anyone will do?Heads up, PP servo is ludicrous overkill for the Felony and is quite an amp hungry thing. You won't get full power from the servo on the stock BEC and could even brown out the receiver on hard turns. I'd recommend picking up a glitch buster for the receiver to be safe. When I upgraded my infraction servo I lost signal during hard turns until I added a glitch buster. Eventually I just started running receiver packs to make sure I was getting full servo power, but you could also do an external BEC instead.
So BEC is a Battery Eliminator Circuit, it is standard on 99% of ESCs these days to have a receiver battery eliminator circuit stock on board, but a lot of the stock BECs have weak power that gets even worse as the ESC heats up from high load. Spektrum 150A ESC is in the neighborhood of 5 amps continuous when it's cool and happy, but when it gets hot that drops to more like 3.5 or 4 amps. Average stock fan will draw around .4 amps continously, some stronger fans can draw upwards of 1 amp alone. Fancy high end servos that run off receiver power (supplied by your ESC's BEC) that are over 25kg usually draw in the neighborhood of 4-7 amps at stall depending on the speed and torque of the servo. So if you have two fans and your receiver powered by the ESC's BEC, in a perfect world you're already looking at only 4 amps to spare. On a hard turn with a 56kg brushless servo, you're gonna be pulling in the neighborhood of 6 amps from the servo alone. When a servo this strong turns, you can actually hear your fans slow down as they lose power. The highest amp draw on a circuit will reduce the voltage of the rest of the circuit and in severe cases cause complete signal loss on your receiver.First thanks for the heads up. now lost with the Bec and glitch buster! lol Bec is for? N I assume the glitch buster plugs into the receiver to protect it??
Yeah on my Infraction I didn't even bother trying the MMX8s esc, I have too many fans and still have the handbrake, plus Savox servos are especially amp hungry. My 2274 apparently draws around 8 amps on stall at 8.4v.I ran into this with a Reefs Raw 500 servo, was browning out the castle esc. Needed an external BEC
Wait ???
