Granite Typhon mega from slow to WOOAHH!
handzace
  1. 4x4-Mega
  2. Felony
  3. Limitless
  4. Kraton 6s
  5. Kraton EXB
  6. Talion EXB
  7. Typhon 3s
  8. Typhon 6s
  9. Typhon Mega
  10. Vendetta
  11. Infraction 4x4
Let’s see those 3s/mega screamers out there !! My Newest project the typhon mega ! I’m gonna change those shocks ,metal spur,aluminum shafts and a blx 185 esc/motor combo from a typhon v4 so it should be a blast on the dirt track ! I did the same to the vendetta and my brother did a mega infraction up we put all the goodies on em and man are they fun! I’ll post up pics of the vendetta and this typhon project …please post pics I’d love to see what others have done to the vendetta and what performance they achieved as well as the mega/3s infraction and typhon !
Very fun platform that is capable of crazy fast speeds.ive done a few typhons an recently have been running my detta for some fast low voltage speeds..currently fastest 3s detta I've ever seen at 124mph..here's a ride on the back of 4s typhon
Did you break the lens on the camera?
So it’s begun! Gonna put a max 8 water proof knock off and 2500 kv motor I had lying around ,I grabbed a light set ,wheelie bar,shocks,axles and a skid plate then I’m gonna go see how she does on the SC these typhons love the dirt! Here’s some pics ,just trying fitment/layout ,put the wheelie bar on and the lights mounted …TBC
Wow! That’s insane on 4s !I too did a vendetta and I’ve got 90 on 4s but problems with the car wanting to backflip at 80mph plus but good thing is it lands on it’s feet 😂🙏lol ! I know the car capable of well over 100 I’ll post up pics of the build …awesome rig brother great video!!!
What are u using for gears in the diffs? Or what diffs? I k ow my vendetta metal internals and ring gear and the typhon has plastic like the infraction so I’m anticipating problems with that ..I got the metal spur dor the slipper in the typhon I’m gonna keep the slipper in it cause it’s gonna be a SC dirt rig ,I locked the vendetta soool .you seem like you have this platform figured out .. good stuff!
Picked this up too……
Springs prepped/fluid and installed …next step gotta mount the esc and instal. The motor and metal spur gear …we almost there! Can’t wait to rip this!
I've run plastic diffs up until 2 days ago when I blew rear diff on 5s.your vendetta is going airborne cause rear-end is squating at 90mph.the second rear squats lower than front I'll go airborne. Here's 1st 4s hit from detta other day...waiting on new 4s packs..should get 130s easy on 4s...
Nice rigs! And runs! Can I ask what springs or shocks or what u did to stop the rear from squatting? I was thinking limitless front shocks all around ….I’ll post up pics of my vendetta I have metal diffs also …it’s so frustrating because it has so much more in it on 4s and I haven’t even done a 6s pass yet 😣
I removed all shocks,replaced with turnbuckles
I've got 5 speedcars,none of them have shocks...I'd try putting a set of tbuckles on rear an give it another try
By the time ya have super stiff shocks on them the shocks are so stiff that they do nothing for you anymore,besides put tons of tension on suspension..with links no tension an also adjustable.
I’m absolutely trying this ! Will post updates! Thanx for the advice I appreciate it!
The @K-BASH shock delete totally works! Done this. to my mega infraction with Spektrum 150a 3900kv combo. Short 600ftView attachment 257107 controllable PB run on 3s @76.7 mph. Dropping a TP 3840kv motor in it this weekend.
Bro that 3840kv will need some power to run it..is it the 4050 or the 3650
Anything smaller than a castle 8s esc will be HOT quikly..these motors are amp hogs.i haven't personally tried this motor,but from my experience with the tp high kv motors they require lots of amps from esc.i love my 3650-3080kv.it'll work most all 6s escz to there limits.maybe firma150 will run with them better than the more unlimited castle escz...🤷‍♂️
This truck looks sooooooo badazz
I've been running 3650-3080kv in mine lately, love this motor...the 3650s are great for this platform.with being a 4500w motor,being 36mm ,420grams make the work great in these cars..
@ChrisC update us on run I'm really curious how it runs together.if it doesn't cut out it scream....just watch esc temps..
Nice !
Nice rig !
Did a hobby wing 120 “made for” combo and wasn’t happy so threw a spare 150 amp spektrum and 2050 kv and wow this thing Rips!! Added Slipper eliminator ,sour gear ,hot racing drive shaft and shaft bearing and couldn’t be happier…under $350 and it’s a savage diffs holding up fine on 4s just like tye mega infraction I did same setup for a while and a blx 3s typhon and no steering Servo issues or stripped diffs and we go hard ….obviously the plastic stock slipper went first 4s rip but that was expected ..was gonna do castke mamba x 6s and a 4050 Tp but honestly it’s overkill not needed especially since this wa built as a track rig …the infraction mega with same setup ram 96 mph pass after pass on 6s 150 amp and both rigs didn’t blow the Cv slides clip or diffs untill foam tires went on so trust me they can handle it ….also same setup for a bit in my vendetta even tho I know they have the metal internal diffs and are stronger in that way stillheld up to all the power I could throw at the 3900 kv with the 150 amp spektrum esc stock motor even ! And the 2050 kv pretty impressive rest to run combo for what it is especially in the light composite mega/3s blx line ! Thinking big rock for my next composite build since my bro did a senton up recently …and gonna throw the 4050 Tp and the mmx6s in the talion 6s v4 ..and 4060 2080kv tp 8s and mmx8s in the tlr 🤔
