Typhon Typhon TLR centre diff leaking ??
powell987
Centre diff on my typhon seems to be leaking diff fluid ?
I have taken it apart and the seal looks fine but once i have it in the car and actually run it diff fluid seems to slightly leak ? Is this normal ? Any ideas how i stop this if its not ?
Thanks
GraniteFox
Delaware
  1. BigRock
  2. Infraction
  3. Outcast 6s
  4. Typhon 3s
Not normal unless maybe overfilled. Could be the o ring on the outdrive side of the diff. Replace it if needed and add the green slime stuff. Stuff works great on diff and shock o rings. Otherwise not so sure where it could leak.
parcou
Hospitality Award
Rig of the Month Winner
Memphis, TN
  1. BigRock
  2. Felony
  3. Fireteam
  4. Granite
  5. Infraction
  6. Kraton EXB
  7. Talion EXB
  8. Typhon TLR
  9. Vorteks
Can you see where it is coming from? Is your diff gasket torn, cuts, or pieces missing on any part of it, not laying flat or well seated?
Maybe let it sit out for an hour, standing up and inspect. Then rotate it the other way and watch it again to see if it leaks before putting it back in the RC.
Warby
"Hurry up and wait"
Hospitality Award
Australia, WA.
  1. ADX-10
  2. BigRock 4x4
  3. Kraton 6s
  4. Senton 3s
  5. Senton Mega
  6. Typhon 3s
  7. Typhon 6s
  8. Infraction 4x4
Thanks
Like @GraniteFox said, I have found that if I overfill them to the point were it spills over when re-assembling them, it tends to leak when running it.
