I wouldn’t waste the money on the belted ones. I spent too much on the Belted Trenchers and they suck doo dooi love mine on the 3s, I was wondering if I should get belted tires for the 6s? will it be an issue?
Thanks.Yes I am buying the kraton hubs and bits at the weekend for it.I am not getting myself the typhon until Christmas but I will have the parts to switch over straight away?
Thread resurrection....My vote is for the MX28 Badlands by a country mile. I know that @Rich Duperbash loves them on his Typhon as well. I don’t know if a better endorsement then that.
The mx28's def grip hard and sling rocks! The tires are physically about the same height, but a little wider. I'd watch high grip surfaces for fear of stripping the plastic diff gears.Thread resurrection....
If you run the Proline MX28s in a Typhon 3s would you need to change the pinion? Is there any risk of burning out the motor with MX28's?
Cheers mate. Will be running them off roadThe mx28's def grip hard and sling rocks! The tires are physically about the same height, but a little wider. I'd watch high grip surfaces for fear of stripping the plastic diff gears.
Yes due to the weight, I would go to an 18T or lower. I believe the stock pinion is a 20T.Thread resurrection....
Have a 15t in mine (v3) is that OK to run with the badlands or would I need to gear up? Maybe an 18t is a nice midpoint?Yes due to the weight, I would go to an 18T or lower. I believe the stock pinion is a 20T.
15T will be fine. You might want more wheel speed for flips and air control, but otherwise it should ripHave a 15t in mine (v3) is that OK to run with the badlands or would I need to gear up? Maybe an 18t is a nice midpoint?
Awesome! Thanks again ?15T will be fine. You might want more wheel speed for flips and air control, but otherwise it should rip
Did you end up buying the badlands for your V3? If so, thoughts?Awesome! Thanks again ?
Hi yea I ran it with the Badlands and a 15t pinion drove great loads of traction especially for off road bashing. When I run them with the 18t pinion my motor gets too hot thoughDid you end up buying the badlands for your V3? If so, thoughts?
How did you mount the tires? Did you get extenders or did the 6x30mm to 17mm adapters give you enough room to mount the tires without rubbing the body?Hi yea I ran it with the Badlands and a 15t pinion drove great loads of traction especially for off road bashing. When I run them with the 18t pinion my motor gets too hot though
I run duratrax xcons with hub extensions and a bigger fan for heat. Never had an issue for the last 4 months.Hi guys I am going to build myself a typhon truggy at Christmas.What wheel and tyre set ups are people running?I know the mx28's are very popular.Oh and it will be for bashing on mainly grass.
