Typhon V2 limitless spool in v5 Typhon?
The long bit on the right side...that's what classifies this as, what is called, a Pinocchio spool.
Compare that to a regular spool.
This is Scorched RC's Pinocchio spool for comparison.
Why are Pinocchio spools used you may ask. Normally, the rear drive shaft is quite a bit longer than the front shaft. This can lead to excessive oscillations at high speeds (particularly with stock drive shafts which are relatively thin and poorly balanced). To alleviate this, they made the spool end itself longer to make the rear drive shaft shorter and, in return, reduce center drive line vibrations. That's one way of addressing the issue. The other, is to use high quality center drive shafts (such as Perfect Pass carbon fiber or Scorched titanium shafts) and a normal spool. Both methods work well and I think it's a bit down to personal taste at this point.
Hope this helps :)
Dang. Thanks guys!
