Note: This feature currently requires accessing the site using the built-in Safari browser.
Personally, I'd go with a Joe Diaz spool if you haven't ordered yet. They're top notch. But that's just me.![]()
The very same. They're outstanding.Are you referring to this one?
https://www.islandhobbynut.com/prod...ium-spool-kit-fits-all-arrma-1-8-scale-models
Will the stock drive shafts work with a Pinocchio spool like that or do you already have some that will? As for what size pinion, that depends on a lot of factors. What motor, ESC, batteries, what speed you want it to go, size of the tires, your skill level and so forth. There's no simple answer to that question. Start slow and work your way up. Best thing to do is to get a collection of pinion gears if speed running is your goal. It's one of those hidden costs of speed running.
What’s all needed to drop that setup in my Typhon.The very same. They're outstanding.
You'd need a spool gear to complete the spool. Then it should be a drop in fit. Islandhobbynut has a great selection of 5mm & 8mm gears.Thanks for the replies. I’d like to stick with the stock esc and motor. I have an assortment of pinions on order ranging from 21-27 tooth, I believe. Also I’ll be running rpm soft version of their speed running selection.
Thanks for all the help, guys.
8mm.Just for my own curiosity, what size is the shaft on the spool? 5mm or 8mm? The item listing doesn't specify.
I'm sure it works fine, I just prefer spools that use regular 8mm pinion gears so I can share them between my spool and motor. This type of spool requires FOH style gears that are bolted in with three screws.I’ve been thinking about doing the same thing
Wondering if anyone knows if these are any good?
It looks good, but from an economic perspective it's not particularly appealing. At least not to me. If you're at all serious about speed running, you're going to spend a couple of hundred bucks just on gears. To have a set of gears you can only use on your spool don't make much financial sense to me as I just don't have that kind of money to burn. Moreover, proper 8mm gears have M5 grub screws that are really robust and I have yet to have a spool gear come loose on me.I understand
That looks good quality!
Man thanks so much for all this. So much to consider. I’m gonna take a look at the Diaz spool.It looks good, but from an economic perspective it's not particularly appealing. At least not to me. If you're at all serious about speed running, you're going to spend a couple of hundred bucks just on gears. To have a set of gears you can only use on your spool don't make much financial sense to me as I just don't have that kind of money to burn. Moreover, proper 8mm gears have M5 grub screws that are really robust and I have yet to have a spool gear come loose on me.
Another thing I love about the Joe Diaz spool is that it doesn't require spacers like many other spools do since the bearings sit on shoulders machined onto the ends of the spool. So you can freely position the gear on the shaft wherever you like. Why is this important? Depending on the length of the shaft on your motor, you may find yourself putting pinion gears on either with the gear towards the motor or the shoulder. This changes where the teeth are spatially in relation to the spool. On the Diaz spool you just loosen the grub screw and move the gear so that it lines up with the pinion again.
These two factors alone are reason enough for me to use them. Yes, they cost a few bucks more, but they come with fantastic ceramic hybrid bearings which, by themselves, already explain the cost difference. As always, these are just my observations and opinions. YMMV![]()
My pleasure.Man thanks so much for all this. So much to consider. I’m gonna take a look at the Diaz spool.
What do you mean by “Pinocchio spool”? Is there a difference between this one and the Diaz version? Just trying To learnWill the stock drive shafts work with a Pinocchio spool like that or do you already have some that will? As for what size pinion, that depends on a lot of factors. What motor, ESC, batteries, what speed you want it to go, size of the tires, your skill level and so forth. There's no simple answer to that question. Start slow and work your way up. Best thing to do is to get a collection of pinion gears if speed running is your goal. It's one of those hidden costs of speed running.
The long bit on the right side...that's what classifies this as, what is called, a Pinocchio spool.What do you mean by “Pinocchio spool”? Is there a difference between this one and the Diaz version? Just trying To learn
