Johnny Polpetta
Hello everyone! As I have written in my intro post, I have recently bought my first Arrma: a brand new v3 Kraton 6s. So far I've been mostly happy with my purchase, although there are some things that have left me sort of a bitter taste in my mouth (the build quality being the biggest head-scratcher).
The truck in itself is a true beast: when I bought it, I had the plan all along to use it and abuse it, so I immediately chose two 3s batteries to run it on 6s. One thing I immediately noticed is that the motor tends to get quite hot very quicly, even though so far the truck has never really been pushed hard.
I tried mounting a fan on it (I even designed and 3d-printed a clamp-style fan mount to use) but it hasn't been a big help. On the last run, the motor got so hot, that the threadlock on the pinion's grub screw melted and allowed the screw to back out, making it gauge the red motor mount and allowing the pinion to move along the motor shaft, causing a bad mesh with the diff spur.
I read around the web that most people run a 14t pinion instead of the original 12t, claiming it is "the sweet spot", so I was wondering: will a 14t pinion help the motor run cooler, or will it just make things worse?
Another thing I need help for, is understeer: this truck has loads of it. To try and fight it, I have changed the diff oils (50k-100k-30k for front-center-rear), removed the sway bars and put the shocks in their softest settings, but the darn truck still won't turn right; sharp corners only happen at low speeds, but press the trigger slightly and they get very wide. The servo isn't to blame, and the tires don't feel too hard even though they're still the stock ones. Any of you guys had to fight this problem? How did you solve it?
Thank you in advance, any help is greatly appreciated!
