I think it’s time for something bigger and better with a better drivetrain than the Vorteks and I thought I might ask about valuing it to sell as I don’t want to rip myself or somebody else off.
The car cost me $370 plus tax and the upgrades cost me $220. Thinking $350 could be a good starting point?
It’s running the stock 3s system, here are all the upgrades and mods:
JX CLS6336HV Ecoboost Servo 35.6kg: https://a.co/d/bLdhI3Z
Surpass Hobby 125mm Monster Truck tires 12mm hex (preglued): https://a.aliexpress.com/_mM5yol4
Rcawd 12mm Extended Hexes: (you need these to use the surpass hobby tires! They are the best solution for using these tires, with no extra or too little offset to mount them without rubbing.
GLOBACT aluminum front steering block & caster block + rear hub: https://a.co/d/adrNZkN
GLOBACT aluminum pivot balls: https://a.co/d/9R1AcZq
FastEddy Bearing Kit: https://a.co/d/g0qnM38
Arrma Outcast 4s motor mount (1-2mm thicker than stock): https://jennysrc.com/products/copy-...uminum-motor-mount-set-heatsink-fan-ara4408v2
YSIDO blue aluminum 30mm motor fan (this thing is amazing):
https://a.aliexpress.com/_mNN5b1s
Powerhobby 57t mod 0.8 steel spur gear: https://www.powerhobby.com/phbarrma56.html
Arrma Outcast 4s 13t steel pinion gear:
https://jennysrc.com/collections/ou...-mod-safe-d5-ara4410v2?variant=40255726321718
3d printed motor brace from thingiverse- due to the way my motor is mounted I had to modify the file and shave down the print. If your motor is mounted the stock way it should work perfect: https://www.thingiverse.com/thing:4982263
I also have a 3d printed cylinder going between the motor and receiver box to keep it from thrusting forward in a crash.
E
I also have a stock spur, stock servo, stock motor fan, stock motor mount (bent back from bend), and stock tires. Should I include these in the deal? Should I put the stock tires back on and keep the new ones?
Trying to keep whatever accessories make sense as I know some upgrades don’t increase sale value so would rather keep.
E
