In the vid that’s full throttle and held open during the vid but then the engine stops and the throttle is still pinned.I don't understand. When you apple throttle nothing happens
Sorry do the vid not show up?Video please to further explain.
No video yet. Just send the video and we will get it figure outIn the vid that’s full throttle and held open during the vid but then the engine stops and the throttle is still pinned.
I have the A and C wires switched. I don’t know what a sensor Ed motor is. I have blx 4047motor pro tech 130 esc 6sLike @Spoc85 took the words out of my mouth
I had that issue you have, I run sensored 8s 1650 and forgot I don’t have to swap wires when running sensored duh me but I did run non sensored 6s 2200 castle where B and C wires are switched only.
I had a non sensored motor and for it to perform correctly I had to switch b and c wires on my 2200 motor. Can you show pictures of motor and escI have the A and C wires switched. I don’t know what a sensor Ed motor is. I have blx 4047motor pro tech 130 esc 6s
Yep that’s a motor out of sync with the ESC. It could be the motor, the ESC, or the wires between them. Inspect the wires first, then swap the motor if needed.Oh? It shows up on my thread
YouTube vid
thanks for your help
I would check that yellow connector. Could be an optical illusion but it looks broken or separatedI was abusing it. Tried to repair but that didn’t work so bought new stuff.
Oh no…. That isn’t a good thing to do. You definitely want the correct connection on all leads. You need to solder new bullet connectors on it if they didn’t fit.The connectors from motor to ESC didn’t just plug in. I crimped them down and shrink wrapped them. I will look into that JD
Okay, I’ll fix that. ThanksOh no…. That isn’t a good thing to do. You definitely want the correct connection on all leads. You need to solder new bullet connectors on it if they didn’t fit.
