- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
Plz guys before you run your rc the most important thing is to check your blinker fluid ok.
I threw mine out..I should have just donated it to someone on here that use itIs that in the tool
Kit? Lol. I never even opened that bag.
I appreciate all the jokes, but having just struggled to disassemble a broken shock, I’ll share that the two parts in yellow help unscrew the shock body. When it finally dawned on me to try using the tool that came with the car, the job was much easier!
When things frustrate me I walk away for a bit then go at it again.I am still trying to figure out how to remove the red part at the top of the shock! It is very stuck (I know right! this is only the first step of the all process!!!)
I am too tired I should call it a day before I do some damage!
Generally the assembly is not consistent I find some screws are very tight and some are more loose. The red ring on the shock are very tight! I am worry I am going to cause some dent or break that red plastic!
No arrma RC is consistent..mass production causes inconsistency.all depends how the china people feel that day on the assembly line..just like the one guy that slaps 3 QA stickers on to assure you that it was tripped checkedWhen things frustrate me I walk away for a bit then go at it again.
I found this in the Vorteks 3s box.
I know the two ends are for the nuts but the ones circled yellow and red I have no idea.
Somebody knows?
Millennial crack pipe. Just a guess.I found this in the Vorteks 3s box.
Somebody knows?
Isn't the hook part circled in red for adjusting the slipper?
