What kind of Rig (PC) you got at home
🇺🇸 DΞזΞפּ 🇺🇸
Cake Boss
Military Veteran
The Boonies, South Carolina
  2. Kraton 4s
  3. Typhon 6s
Show your PC and what you got in it, did you build it? you can't possible do all the work on a Smartphone lol.
I got to get ready for work, will list all the guts later on.
I used to run competition on HWBOT with team ROG ASUS.
Video
yeah I just crossed referenced it, it will work.
Looks like it will be a Tank :)
CPU Cooling wise for your rig I would go with a closed loop one, Corsair is usually good, it depends on if you like a lot of LED's so you can get a seizure from all the strobing :p
shop around 120mm radiator should be enough, make sure you check the thickness of the radiator, the thicker the better.
I currently have a 240 AIO and I think I am going to ditch it for a D15.
Noctua was one of my fav. but they are huge lol
and it wasn't cooling the CPU enough for what I was using it.
in what application?, I give you an app and your PC will fail if you run it with the Noctua.
Like I said that was last I checked maybe a few years ago.
My current AIO can't handle much over stock speeds without thermal throttling.
Oh ok, try to get the thickest 360 if you have room. your GPU puts out a lot of heat when gaming, you have to have efficient air inside the case or it will be an oven with the Noctua, maybe start a custom water loop build :sneaky:
How's the 5700G working for you? I was running a 3400G before getting a GPU. Buddy of mine is looking at getting one of the new APU's from AMD. Probably the 6 core, 12 thread one.
