Reaper 007
I need help..what's the proper procedure for setting the droop screws..I keep tearing out shock rod ends..
^ I do that but I adjust to the end of shock travel. undo the shock, let the arm hang down, adjust droop screw until you can slide the shock pin in/out smoothly without compressing/extending shock.
adjusting to slightly having to compress the shock in is the safer way. gives you a little bit of leeway if there's some wear on the droop screw/chassis.
^you're right about that. I'll be readjusting my droop screws
do you run stock arms or rpm? I used to run rpm but they tend to sag bad after a while. the stockers keep their shape a bit better and i have yet to brake one
