Does this mean my axle has unscrewed?
Looks more cambered than other tires. And the tire wobles like crazyMost RC cars have some camber from the factory, usually between 1 and 2 degrees. It's normal, and it doesn't mean there is a problem with the suspension or axles. Do a web search on "camber" and you will find the advantages and disadvantages of different camber settings. If you are still concerned, check the wheel nuts, driveshafts, and axle carriers to see if they are loose or damaged.
Something is loose going by wobbles like crazy..do what senton prime suggestsLooks more cambered than other tires. And the tire wobles like crazy
I'm sure you already took the wheel off and inspected .that would be your first move before dropping questions on here as to what could be wrong.you already mentioned it wobbles like crazy.so your first check should be everything that's on that wheel.take it all apart.if you see nothing then tighten it all up and see if wobble is gone..you will get a small play ..that's normal but not wobbly like you say.i hope you trouble shoot it.good luckSomething is loose going by wobbles like crazy..do what senton prime suggests
I already checked 2 times. But 3 time strikes my wheels hex na spot was bent in and it couldn't hold the hex in placeSomething is loose going by wobbles like crazy..do what senton prime suggests
Good job finding the problem.looks like u need a set of wheels.I already checked 2 times. But 3 time strikes my wheels hex na spot was bent in and it couldn't hold the hex in place
Fixed it with heat and a hammer no need.Good job finding the problem.looks like u need a set of wheels.
Ok if you say so.Fixed it with heat and a hammer no need.
