FireDrake001
- Typhon Mega
I am curious will the XMaxx motor fit the sledge? It is a 48mm diameter
Isn’t the Sledge motor a 4277mm motor, I think it’s just a tiny bit longer than a 4274. Either way, Slick is right. Unless you do some serious modding it won’t fit. Wouldn’t mind having one to mod a larger motor in it though….I do not think so. I think you are limited more by length than diameter. Pretty sure the stock length motor is the longest you can fit in it without modifications.
Stock Sledge motor is 4274 and almost hits the bellcrank. XMaxx motor is 4885. That does not look like 9mm between the back of the motor and the bellcrank.
