calebgilmore
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
- Voltage
Started on an on road and off road typhon build this week. Started with the on road, taking a v5 typhon chassis, senton arms/drive shafts, infraction towers/shocks and a max8 g2 2250kv combo and got it set decent on a Delta Plastik BMW body. I have some more jaegermeister decals coming that will fit the sides better. The number/driver decals are big too but i'm rolling with them since i couldn't find the same ones in a smaller scale. I goofed the front body mounts a little and centering them up but it came out ok. The tires barely clear the front when turned left or right.
Second up was the megalodon bodied typhon chassis. I used Just Bash It chassis/towers/ackerman/top plate/wing mount anchor/+2mm hex extenders, servo mount, and a basherqueen max6 holder. It's running talion towers, fireteam shocks and mojave arms as well, with the megalodon body. I screwed up the body post holes on this one as well and have another body coming. The black one is now discontinued but i found one on Amazon. The black tough body material is light and bends easily so we'll see how well it lasts. I was hoping to run the udr tires on the vitavon wheels (arthur confirmed they would work on mojave wheels and i had my doubts. Tried it today and it wasn't working so well so i went with hyrax instead) but settled on the hyrax today. I had initally set it up on the cheapo udr/mojave wheels from amazon/aliexpress. I found out i was short 2 non exb shock mount pins so i had to order more and stick the longer ones through to hold the shocks for now to keep going and get everything working together. Both cars have some kockoff aluminum hinge pin blocks and center braces from ebay too by the way. I'll decorate the new body for the megalodon when i get it in and finish up the on road car as soon as i get the decals in from canada.
