Kraton How well would this combo work out in a KXL.
fredw90
It’s a damn good deal but the low KV worries me a little. Not going for any dumb speed, I’d be more than happy with 50-60. I know the 1650kv would be preferred but that combo is more expensive.
Or…. Should I just wait for a max6 g2. I do like my max8 g2 in my tekno….
But I’ve also never owned a full castle setup in at least 15 years so I feel like I’m missing out.
1650kv's is better suited for 6s running.
You are looking to run 8s with 8s electrics?
Or not?
You can run 6s packs with any 8s ESC, FWIW. Commonly done.
Not sure what your plan is.
I have a couple of those MMX8S/1260kv combos and run them on 6S. Fireteam. Infraction. It's a great combo - big power, smooth throttle, and automatic motor temp cutoff.
I have several 1650kv 1717s as well and can't tell any difference in power between those and the 1260kv.
Gearing that 1260kv 24/50 should get you to about 60mph in the Kraton. (on 6S). You'll need a smaller spur gear for higher speeds.
What kind of temps are you getting with that gearing? I did try out a mmx8s with the spektrum 1250kv a year ago, and it got toasty but nothing too crazy. Shouldn’t have sold that damn truck 🤦🏻‍♂️.
Fireteam geared for ~60mph doesn’t need a fan except for middle of summer. Gearing any higher would need a fan year round.
Infraction has a 4028 fan on the ESC and two 4028 fans on the motor. Geared for high 70s and can bash all day regardless of outside temp.
I have both set to auto cutoff if the motor reaches 180F and that never happens. Typically 140-150F max on each setup.
Well I ordered it. Was on the fence about picking Up a mmx8s and figured couldn’t hurt to get a motor too for another $50.
