You are going to want to change out the slipper/spur to the 3S BLX unit. The teeth are bigger (32p vs 48p) and it will hold up better to the additional power. You will need to change your pinion to 32P as well. I would go with a 15t pinion and a 3S BLX motor mount. Probably wouldn't be a bad idea to swap in the 3s BLX diffs too. It adds up quickly. Personally I would just buy a 3S BLX Granite.Would this be a good upgrade from brush to brushless on the granite mega 4x4. If so should I run 14T or 17T? Will I need a program card?View attachment 40573
