1/8 motor heatink/fan combo into Spektrum receiver?
The_Otherside
Huh?
Military Veteran
Appleton, WI
  1. Mojave EXB
Hello! One last thing thing I need!
Can someone point me in the right direction?
Castle Monster Mamba X 8s.
I'm looking for fan a fan and heatsink for the motor that plugs into my Spektrum receiver.
Does that exist? Thank you!
Edited for clarity.
"Spektrum" "fan" and "receiver" yield a lot of different results. 😅😅
Not sure how to word the search.
1250 8s motor with 8s arrma heatsink and 2 40mm trinity aluminum fans
If you want it to run all the time, yes plug it into the receiver. If you want the ESC to control it plug it into the ESC fan port, it will only run when needed.
Hard pill to swallow if you want to make sure that your fan works.
Try 'motor heatsink' as a search term, 3 letter words will not work in search.
Castle motors already have heatsink fins. You add a heatsink and your your guna hinder cooling.Best to find a clamp style mount for your fan.
So that's all those "rings" around the can??
There's so many Google results :( do you have a preference?
Didnt say don't run a fan. But a heatsink on a hobbywing or castle is going to hinder your fan/fans. Not enuf contact ther for it to transfer heat. Go ahead and cause more heat. Been ther done that. Atleast fill your voids with thermal tape/ putty.Goodluck 🤘edit: i have a fan on 4985 gets way cooler than with a heatsink and fan.
