- Outcast 8s
- Typhon 6s
Wanna get sum new bearings need to know the size thnx
don't have the motor in yet figured since I was getting bearing for the car might as well get one for the motorJust pull the front cap and measure it. It's going to be an 8mm ID...that much I can tell you.![]()
Yeah, get two though. You have one on either end. I dunno what the size is on those but I'm sure someone must have swapped bearings on a 2028 by now.don't have the motor in yet figured since I was getting bearing for the car might as well get one for the motor
In that case get 4 so I can have sum for my outcast. It has 2028 1100kv didnt know if they would be the same size though that should help with the search thnxYeah, get two though. You have one on either end. I dunno what the size is on those but I'm sure someone must have swapped bearings on a 2028 by now.
I don't know that for certain, but it's probably safe to assume that they are. I'd suspect that they used the same can for the 1700kv version. And, just to be sure, take measurement of both the front and rear bearings...just so there aren't any weird surprises that they used two different sized bearings for whatever reason.In that case get 4 so I can have sum for my outcast. It has 2028 1100kv didnt know if they would be the same size though that should help with the search thnx
Yeah I just seen the 800kv came out with 2 different size bearings. You would think they would make that kinda info more accessible since its a perishable part. It should be here tomorrow so I can check thenI don't know that for certain, but it's probably safe to assume that they are. I'd suspect that they used the same can for the 1700kv version. And, just to be sure, take measurement of both the front and rear bearings...just so there aren't any weird surprises that they used two different sized bearings for whatever reason.
