Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
- Thread starter
- #61
Thanks again man. I tried it and could tell a slight difference. Not having done this before I don’t have a feel for it yet, but I’ve 2 of the similar brand 25kg ones that failed last year I’ll practice on eventually. I’ll be installing the one I worked on soon as the servo mount arrives.Bottom BB is sandwiched, pressed snug between the output shaft and the potentiometer. You can leave as is. Not an issue. The top BB is the focus because only this one has that poor fitting O-ring. The upper case contributes much to this also. No recess for the O-ring, so it gets pressed hard into the unshielded BB.
I see you got to that upper BB O-ring. If you place it over the BB you can see that it will sit inside the race and against the BB cage and bind up the BB.
Try the fit with and without the O-ring, you will see how the BB locks up with the O-ring. I see this with many brands of Servos. Expensive ones also.
Futaba's however, for instance are made much better by comparison. And this does not happen.
potentiometer…I’ll google that later
