UPPERDECKER
- Mojave EXB
Hey guys, first arrma, and before even driving it I can see how they carry their reputation so well.
I'll lay down my spec sheet first, still looking for tips and tricks on the how to's and maybe anything else I might have forgotten along the way. I tried to number them in order of install but it's a loose order.
***POWER***
1. 10K-30K/500K/10K-30K F/C/R LSD DIFFS
2. FLYSKY GT5/BS6
3. SAVOX 2210SG-BE
4. CASTLE 1717 1650kv
5. 19-22 TOOTH PINION
6. CASTLE MAMBA XLX2
7. CASTLE BEC 2.0 WP
8. ZEEE 4s 9000mah (8s)
***SHOCKS***
--SPRINGS--
SOFT (70mm, 7.7 lbs/in - 110mm 3.2 lbs/in)
STIFF (70mm, 8.6 lbs/in - 110mm 3.6 lbs/in)***
STREET (60mm 9.7 lbs/in - 95mm 5 lbs/in)
1. SHOCK OIL 90W
2. SWAY BAR FRONT/REAR (STIFF 2.9mm)
3. TEKNO RC DROOP SCREWS
***PROTECTION***
1. DRYWALL TAPE/SHOE GOO BODY
2. DUAL FAN MOTOR COOLER
3. DUAL TRAY TOP/BOTTOM BATTERY TRAY
4. SHOCK BOOTS FRONT/REAR
5. DUSTY MOTORS XXXL UNIVERSAL SHROUD (CUSTOM CUT)
6. SCORCHED EARTH REAR AXLE GAURDS
7. SCORCHED EARTH FENDERS/MUDGUARDS
8. BODY POST FOAM SUPPORT
9. BODY EDGE PROTECTION TRIM
10. M2C 2MM EXTENDED WHEEL HEX
11. CUSTOM CUT WINDSHIELD
***COSMETIC***
--LIGHTS--
1. LIGHT BAR
2. HEADLIGHTS/TAILLIGHTS
3. UNDER LIGHTING
4. HORN
***WEIGHT***
CHASSIS 169 oz
BATTERIES 52 oz
ESC 13 oz
MOTOR 21 oz
BALANCE WEIGHTS 18 oz
~17 LBS RTR
***POWER***
2. FLYSKY GT5/BS6
3. SAVOX 2210SG-BE
***SHOCKS***
--SPRINGS--
1. SHOCK OIL 90W
***PROTECTION***
***COSMETIC***
--LIGHTS--
1. LIGHT BAR
3. UNDER LIGHTING
4. HORN
***WEIGHT***
CHASSIS 169 oz
BATTERIES 52 oz
ESC 13 oz
MOTOR 21 oz
~17 LBS RTR
