Do the rpm arms require the spacers? Just wondering if the stock has to much play in them and this is why the screw backs out.I broke my stock a-arm about the 3rd rom 4th pack and been running RPM ever since so i didn’t have the originals long enough to experience a problem personally
Those spacers on the top arm are for caster adjustment. If your screws are backing out, then it's likely the holes are stripped or elongated. If buying that piece where they bolt into, https://www.arrma-rc.com/part/AR330379, then I wuld suggest you put a little CA glue in there, right before you put the bolts in. It's a temporary fix at best.Do the rpm arms require the spacers? Just wondering if the stock has to much play in them and this is why the screw backs out.
Ok thanksThose spacers on the top arm are for caster adjustment. If your screws are backing out, then it's likely the holes are stripped or elongated. If buying that piece where they bolt into, https://www.arrma-rc.com/part/AR330379, then I wuld suggest you put a little CA glue in there, right before you put the bolts in. It's a temporary fix at best.
