Skaxis
- Points
- 178
- Fury
I bought my 2nd fury this past June. This time a BLS. The previous Fury was a Mega. I have less than 6 battery packs through this truck and the motor is done. It sputters, stutters, and shimmies but doesn't actually go (much). I tried it in my sons Losi XXX-SCT with the same result so it's not an ESC or transmission issue. I ran the Fury on a professionally maintained clay track for 4 battery packs. 1 pack was at the local school play ground which is covered in pea stones. The last pack when the motor died was an empty parking lot.
The Mega 15T motor died in 3 battery packs. 2 in our close-cut grass yard and 1 at the play ground.
The warranty covered the first motor and I'm sure they'll cover this one. I'm not super impressed with how quickly these SCTs are toasting their motors. I ran the Mega on a Tamiya Dirt Tuned (25T) brushed motor for months under the same conditions with no issues at all. I've since upgraded to a Castle Sidewinder SCT combo with 3850 Kv brushless for over a year and it's been totally fine (except for the failed power switch which I understand is a common issue with Castle). So it's not how I'm running the truck. It's the stock setup from Arrma that's weak.
