One of those "cheapest worth having". The zoskay specs are exaggerated. Metal gears are preferred. Some servos use less durable plastic. Even better if they offer a rebuild kit. Most servos stop working when the gears get chewed up. The stock senton servo less than 7kg at 0.14 seconds for each sweep. If your a big nerd, you can build a servo tester.. like this one.I just bought a zoskay 35kg high torque one… $&@?! I just seen it’s a metal gear one! That’s not okay, or is it? Im so noob at this. Please help! Lol
Metal gears are good.I just bought a zoskay 35kg high torque one… $&@?! I just seen it’s a metal gear one! That’s not okay, or is it? Im so noob at this. Please help! Lol
Aren't the stock servos brass?Metal gears are good.
Plastic gears are Bad. (Best for Air planes and Helis)
Most Surface RC servos will be Metal geared.
Brass and Aluminum gears are the weakest/cheapest and strip easily with impacts.. SS or steel gears are strongest.
