You can use the Outcast 4S arms on a granite, but there’s a ton of other parts to use them. Basically everything outside of the chassis. Better off buying an actual Outcast instead. The closest thing to easily widen your Granite is Typhon arms. You will also need the longer turnbuckles.Almost finished with Frankenstein ! Just curious if anyone else has done this, cant find anything on extended granite mega...p.s. it all started because I wanted to put T-Maxx rims and tires on it !
I'm on typhon arms now, forget witch ones. But ya it's all typhon front end. Waiting on motor in mail, I'll be brushless next week. Oh yeah, bruh if I wanted a outcast I'd buy one. You don't get into this hobby being cheap. I thought this website was about being creative and customizing. Not about buying a outcast like everyone else..You can use the Outcast 4S arms on a granite, but there’s a ton of other parts to use them. Basically everything outside of the chassis. Better off buying an actual Outcast instead. The closest thing to easily widen your Granite is Typhon arms. You will also need the longer turnbuckles.
