Bent shock Arrma Outcast 4S
mad.buford
Evening all
One of my front shocks on my outcast 4s is bent. Can just the metal piece be replaced? I would obviously have to take it all apart etc.. and rebuild with shock oil.
I'm looking for a part number but cant find one on the exploded diagram the car came with but I've seen people rebuild these on some Arrma models?
Any advice is appreciated
Thanks
Evening all
Thanks
I believe the shaft is vulcanized into the lower cup.. so basically no.
You can buy the whole set for $37 at JennysRC.com
https://jennysrc.com/products/arrma...st-oil-ara4408v2?_pos=30&_sid=7f0a67aa9&_ss=r
The shocks that you see folks rebuild are either the 6S or 8S shocks
or aftermarket units.
Thanks all. Another question for you all, is there a part number for the picture attached. I have seen this before being sold but cant find it anywhere
Thank you
Thank youView attachment 324900
Yes.
But you can probably get the whole shock (in a complete set) cheaper at JennysRC.com
You only need this part ARA330706 https://www.arrma-rc.com/en/product/shock-shaft-4-x-62mm-2/ARA330706.html
Or this one depending on if it is the front or the rear ARA330707 https://www.arrma-rc.com/en/product/shock-shaft-4x73mm-2/ARA330707.html
The short ones are the front the long ones are the rear.
Yes.
What he said. Just buy the whole set and have spares.
He can almost buy 4 pairs of shock shafts for the same price as 4 shocks. 4s shocks are $37 before shipping on Jennys shock shafts are $9. I don't see a lot of people damaging their 4s shocks so I would rule this as a case of bad luck and do not see the need in having an entire spare set of shocks.
Good point, good point. Only issue I ever had on my Big Rock was pulling the ends out.
