Vulthraxis
- Thread starter
- #21
Here you go you were the one that started the seems so that is 100% something I was using because you used it here
You then make this post
Here we are to the SEEMS to only fit BRCC6s part remember you used it first.
First thing you did was take the post name 6S gaskets and tell every one it only fits the BRCC6s is this not a discredit to the information I provided, Simple English.
Bro you can attack me all you want on here I'm never going to care about your additude when given proof by link you choose to ignore the facts presented and go with what ever first came to mind your first point was shot down before it went up and you second was a not well thought out mess showing you didn't even bother to look at the links and no cross reference.
Take more time with your sources and get your facts right before you go making a bunch of statements.
I then link you the items from the big rock listing you say in not in there library but is up there on there sight as shown in the post after the quoted post
Trashing another member. And all most every pro quarter mile car out there has honda bond in it if were no talking about street cars so yeah these are more scale race cars less street cars. If it has a motor plate for mounting its got honda bond that is a silicone. They don't make 1 off 1 use gaskets for motor plates and I would be safe guess for me to say they go fast then you have ever bin on land.You cannot compare caulking around a bathtub to sealing a differential. First of all, a gasket works in a compression state. You are aware that automobiles have gaskets on engine, transmission, differential components, right? Applying silicones instead of a gasket is a last-resort and only hacks work that way. Plus, it shouldn’t be used as it will eject itself from the two mating surfaces once clamping force is applied… making is useless.
What you wrote makes sense BUT a lot of things “seem” to fit. Arrma hasn’t posted the truck in the library yet. Maybe tomorrow? Only way to know for sure is the cross-validate once the exploded views and/or parts list goes public.
If the BRCC6s uses the same part-number cases (see below) as the entire 6s line, it’ll fit.
https://www.arrma-rc.com/en/product/gearbox-case-set-hd-6s/ARAC5006.html
I at this point have kept the conversation as clean as I can and will no longer be posting in this thread.Discredit your post? If I did, it wasn’t intentional. Your arrogant and belittling words say a lot about how fragile your ego is.
Gaskets, orings, backup rings, and seals (and some wiper designs) work to keep lubricants in AND to keep dirt out. Not just keeping grease in like you stated.
Grease main function is to lubricate a wide variety of components. Some use it for sealing purposes, but hey, to each their own.
