I’m a beginner. What does binding mean? What oil is recommended? How can I check the diffs without taking them apartMy Arrma kraton exb 6s has a grinding/clicking noise coming from the gears. Is this normal, what should I do?
I would take the diffs apart and give them a good looking over. Make sure they aren't binding and they look as they should. Probably need to add your preferred weight oil (factory is often light in adding oil) and make sure the factory assembled them correctly. You can check this by looking in the exploded view in the manual
Here’s a link to a video>https://share.icloud.com/photos/01auqOMjbOyq16L5yi92ehZhACan you post a video of the noise? Might be normal, metal drivetrain's are noisy.
In order to properly check the diff's out you will need to disassemble them.
Don't worry about the weight. When you take them apart, there should be a good amount of oil in there. If it's dry, look in the manual and just add what they included stock to start with. As for checking for binding, just make sure they rotate when you manually turn them. Also, RCbuzz is right, metal gears are noisy. Might just be that.I’m a beginner. What does binding mean? What oil is recommended? How can I check the diffs without taking them apart
Sounds like all of my 1/8 scale vehicles.Here’s a link to a video>https://share.icloud.com/photos/01auqOMjbOyq16L5yi92ehZhA
Thanks!I would take the diffs apart and give them a good looking over. Make sure they aren't binding and they look as they should. Probably need to add your preferred weight oil (factory is often light in adding oil) and make sure the factory assembled them correctly. You can check this by looking in the exploded view in the manual.
Ok, Thanks, I didn’t think anything could be wrong as it is brand new.I'm pretty sure what your describing is completely normal. Especially if you're new to RC. It's the metals gears making contact with each other as you roll it.
If what you mean is once you got the wheels on it and no batteries as your roll ot back it forth, you are hearing the differentials and spur/Pinion gears making contact
Well… sorry to rain on your parade but I don’t trust RTRs. I have ALWAYS taken apart my diffs before use. As many have stated, take them apart and follow the YouTube videos posted.Thanks!
FWIW, that sounds completely normal for a metal gear RC.Here’s a link to a video>https://share.icloud.com/photos/01auqOMjbOyq16L5yi92ehZhA
Thanks!
6) use the manual and exploded views as needed.Well… sorry to rain on your parade but I don’t trust RTRs. I have ALWAYS taken apart my diffs before use. As many have stated, take them apart and follow the YouTube videos posted.
A few suggestions, if I may?
1) Buy a quality set of hex drivers.
2) Start with one diff at a time.
3) Label everything.
4) Take photos for ease of assembly.
5) When in doubt, reach out. We’re here to help.
