Caracal RC
- Granite
Hello everyone,
I wanted to share with you a 3d printable Wing Mount I remixed specifically for the Arrma Granite 4x4 3S BLX v2. I think that it should work for other cars like Big Rock or other 3S line cars, but I can't be sure because I can't verify as I don't own those.
Thanks a lot to the original authors.
This is a copy/paste of the description I wrote for the "thing:4802854" I just uploaded.
This is a remix of the already great Arrma 3s/4s TPU Wing Mount.
For the Arrma Granite 3S BLX v2, the following issues of the above "thing" have been fixed :
Note: Photos show a print with TPE filament that almost failed (the left part of the wing mount), that's why the two parts are not stuck well. It works anyway. Your print should be much better than mine.
Print Settings
Printer:
BIQU Thunder
Rafts:
Doesn't Matter
Supports:
Yes
Infill:
50
Filament brand:
Any
Filament material:
TPU or TPE
- Space between holes that goes around the body post towers was two high, so I reduced it to exactly the space there is between them (24 mm between the center of them).
- As the original part from Arrma, the body post couldn't be pushed as far as it should be once the wing mount is installed on this specific car, so the body was siting higher than expected and the wing was a little to low compared to it.
- Some new holes had to be done on the truck for the screws of the body post. This is not needed anymore, the existing ones can be reused.
- (3) M3x40mm screws
- (3) M3 locknuts
- (3) M3 washers (used under the M3 locknuts, optional but recommended)
Print Settings
Printer:
BIQU Thunder
Rafts:
Doesn't Matter
Supports:
Yes
Infill:
50
Filament brand:
Any
Filament material:
TPU or TPE
