AR10874, the part with "pull" block- melted, rear AR310783- melted and AR310873 have gear teeth "bented"
hello everybody, in the arrma kratons instructions they write to unscrew a little the clutchs screw. but today the clutch melted and broked a lot of pieces. how i can resolve this?
Well, to answer your question….you’re going to have to remove and replace. Upgrade parts are available If you choose to go that way. We’ll do our best help you figure out what is needed. Pictures will help. Hard to say without seeing whether you have a clutch or diff problem. Or both.hello everybody, in the arrma kratons instructions they write to unscrew a little the clutchs screw. but today the clutch melted and broked a lot of pieces. how i can resolve this?
HereCan you send a picture so I can help you resolve your problem
Last time I looked they’re out of stock.Based on how that looks I believe you going to have to replace most of those parts Jennys rc is a great place to get cheap parts
Thanks but I saw a lot of people don't unscrew the clutch. Is it safe or with time the problem comes again?Based on how that looks I believe you going to have to replace most of those parts Jennys rc is a great place to get cheap parts
To me I would think that a 1 in a hundred chanceThanks but I saw a lot of people don't unscrew the clutch. Is it safe or with time the problem comes again?
I had similar problem the screw came out lost the spring was really easy to fit new one I over tightened at first she was popping wheelies everywhere I have loosened back of a touch now not so crazyhello everybody, in the arrma kratons instructions they write to unscrew a little the clutchs screw. but today the clutch melted and broked a lot of pieces. how i can resolve this?
