Badam
- Senton 6s
I am assuming that metal to plastic meshes better and is more durable?Its not really the oil number, but combination as a whole. I would go 20k in rear, 100k center, and 50k up front.
Remember power will go to where there is less resistance. So lighter fluid, thats where it goes. Its almost as running lock diff, will feel like a rear wheel drive car and kill the 4wd advantage.
** Exactly about the 4S, I run 4 and 5 (esc set to nimh) and tracking w my watch chrono, and if you pay good attention you will know, because as the battery wears out it will be more difficult for the truck to wheelie and go over jumps, and quick blips on the throttle will not be as responsive.
I got a 6s, and only once in a while to show off as you say or when going jumping as it as much more torque, but I try not to do long high speed passes because it will destroy the tires. Also, the tear and wear on the pinion is almost immediate, small metal shavings can be seen in the chassis regardless how well the pinion to spur was set up.
I don't know why they don't have a plastic spur gear option. On my 5B its metal pinionto plastic spur and I have bashed that poor baja on a 30.5cc engine and still no broken parts. On my on-road 1/8th nitro setup is metal to plastic and unless the engine moves, the spur gears hold fine, but well its just some silly forum venting... lol
I will buy the weight of oils you have recommended. It sounds logical the way you put it thank you very much for the advice as i am new to the hobbyI am assuming that metal to plastic meshes better and is more durable?
Sorry for the million questions but will 100k in the rear keep it from doing wheelies as much. I like wheelies but i don't have a wheelie bar and i end up destroying the bodyI am assuming that metal to plastic meshes better and is more durable?
When it flips backwards that isI am assuming that metal to plastic meshes better and is more durable?
