enk_rcs_on_tiktok
- mn
- 4x4-Mega
- Limitless
- Kraton 8S
- Notorious
- Senton 3s
- Senton Mega
- Typhon 3s
- Vendetta
Get as many as you can afford (they add up quick...a hidden cost of speed running rarely spoken of). And get a center spool. Aside from the propulsion benefits they can provide, they also make it possible to share the same gears for pinion and spur gear (assuming your motor, which in this case it does, has an 8mm shaft).i need pinion ideas for my 8s limitless i have a xlx2 and a 2028/1700kv
Is there something wrong with the stock spool?And get a center spool
What are your speed goals? What website or app are you using to calculate gearing and speeds?i need pinion ideas for my 8s limitless i have a xlx2 and a 2028/1700kv
Generally speaking, no. However, and please correct me if I'm wrong cuz I might be misremembering, if memory serves, the v2 spool has a through hole for those grub screws on Viagra® to work with the Arrma style spur gears and lacks a flat area to snug your regular grub screw up against. Not that you couldn't grind your own flat spot and make it work as round faces aren't well suited for your more typical gear type and Arrma's own selection of spur & pinion gears is a bit anemic but that was the general thought behind "getting" a center spool (though it would have to be a Pinocchio style spool for the v2 motor position and drive shaft arrangement).Is there something wrong with the stock spool?
Welcome. What Spur do you have, 34t or 39t?i need pinion ideas for my 8s limitless i have a xlx2 and a 2028/1700kv
If you're just getting your feet wet in speed running, definitely start out on lower voltage as @TN-RC suggested. I'd even go one further and start on 3S, provided you have a sufficiently long road (lower voltages require a slower trigger pull to help counteract voltage sag). I learned more about speed running on 3S than I ever did on 6S. The speeds are lower giving you more time to react to the inevitable and unexpected things that the car and the environment will do while at the same time forcing you to really get the car dialed in to go faster rather than simply throwing more power at it (which will inevitably end in disaster because not enough time was invested in understanding how to set the car up and how to tweak it so that it's stable). Even on 3S speeds north of 130mph are possible.I’ll piggy back and subbed. I want to know too. But for a Felony that I want to run Limitless gearing. Good stuff gentlemen!
Top notch good sir o7I have now changed my mind. lol. I already have a Mamba X and 1717 combo. I’ll stick to FELONY gearing. lol. Thanks for the quick lesson @Diem Turner Ill just stick with what I have sir! I’m already running 6-8s.
its a v2 i think im gonna put a 48/23 gear ratioWelcome to the forum. Is your Limitless a v2? if so a 32t is the place to start. How fast are you looking to go? 32T should put over 100 mph but you are going to need a lot of good road!
thanks so much!Get as many as you can afford (they add up quick...a hidden cost of speed running rarely spoken of). And get a center spool. Aside from the propulsion benefits they can provide, they also make it possible to share the same gears for pinion and spur gear (assuming your motor, which in this case it does, has an 8mm shaft).
That's a Top Gear Top Tip to save a little of that hard earned cash.
Aside from that, what they said.
48T pinion?its a v2 i think im gonna put a 48/23 gear ratio
thanks so much!
yeP!48T pinion?
that's way to high. your stuff will just cut, or the batteries will get stressed. If 48/23 would work, you would go over 300mph.yeP!
im trying to get 150+ what gearing should i run??that's way to high. your stuff will just cut, or the batteries will get stressed. If 48/23 would work, you would go over 300mph.
If you are going to start with 8S you should do a max ratio of 2/3
I got 104mph on 8S with a 160A ESC under 90% power with 28/34 gearing about the same kv motor.
Feeling stupid today, what does "o7" mean exactly?Top notch good sir o7
Not at all, I thought you'd never askFeeling stupid today, what does "o7" mean exactly?
