fishycomics
As I watched a video, asked my question and will ask here at the Arrmaforums.com...
I run other rc models. a 3670 motor 2500KV 80-120 Amp Esc. The Arrma Tailon is a 2050KV and 180Amp.
So why are we saying that I must use only 4S or 6S set ups, and anything less then 30C will see pic 2 be an issue, where as. I am running a 4000 mah 30C rated one, 3500 mah 25C rated one. and no issues at all.
A) yes the battery gets heated to a degree,
B) run time will differ due to the amount of **** Mah used
C) C rated is for quickness for X amount of seconds.
I am still with my other Rc model no issue day one. owner of it since March 2017, about 500 runs at least on it most 4k mah 30C some 3500K mah 25c..
I ask my question why is Arrma or us telling others to keep to 4S-6S, are we saying it's advertisement forcing you for speed, that is my thoughts out loud and like a answer that makes sense to this.
Pic 1
Pic 2
FISH
Added note. As I was told you more or less must dedicate 4S or 6S batteries to your 4-6 set up and not separate to single batteries. to keep the Balance consistant and in order/
Pic 1
Pic 2
FISH
