Apkallday89
- Points
- 38
Hi there just put in a castle Mamba Monster 2 combo with the 2200 KV into a Typhon 3s was getting about 80-mph on stock motor with 26 tooth pinion and 50 t spur the diffs were barely able to handle the original Electronics with that gear ratio third rear diff installed now only using it for Speed runs I'm probably guessing I'm going to have to swap to the metal diffs because I'm planning to run it 6s with them on the Mamba Monster wondering what kind of mile per hour I would be getting if I'm getting 80 with that ratio on stock Electronics now going to 6s with same ratio
