jimbulsara
- 4x4-Mega
- Thread starter
- #21
This together with @Cheapbastard post gives me a good map on how to proceed. I just have one last question between this esc and the one the @Cheapbastard suggested which one is best? Would I be able to use the 3650 motor with either?The BLX100 ESC would work with most any brushless motor, so long as it is not a big 1/8 motor. And yes, it would be better than the Racerstar I linked.
For Max10 vs Max8, realize there are two different Max10 - the regular max10 - 100a, and the Max10SCT - 120a. Many of us think the BLX100 ESC is a Max10, and the BLX120 is a Max10SCT, both with Arrma programing.
One last thought on the motor - the motor shaft. Seems like a minor thing, but most 3650 will have a 1/8" (3.2mm) shaft, most 3660 will have a 5mm shaft. You mega has a 1/8 shaft, and most 48p pinions have the smaller 1/8" shaft. So if you get a 3660 motor, you will have a harder time finding a 5mm 48p pinion gear.
Last - motor size and batteries - if you go with a 3660 motor, your Nimh batteries will have trouble. Nimh really will not support big amp loads very well, which is why I was suggesting the 3650 size motor.
Thanks to everyone who chipped in. I am amazed on how many people replied with such detailed post. I am a complete noob, but this lockdown has given me an itch for upgrades and I want to scratch it. What a great community. I will update once I buy an esc and the motor. I will most likely buy one of the esc that I mentioned here either the blx or the one the @Cheapbastard suggested. Thanks again
