Jwill1316
Hello all im new to this group but was hoping to receive some help. I have exhausted all option trying to figure out what could be wrong.
This Vortek is brand new out of the box. Car drove fine for about 10 min and now I have complete binding and steering issues. I have tried to bind this without AVC as well as with and I have the same result.
As soon as I bind the front tires turn hard LEFT or RIGHT. As well as while trying to calibrate after binding it will not calibrate properly. Any help would be accepted. I have reset both remote as well as the receiver.
All batteries are new and fully charged. All trims set at recommended positions. AVC 100% Brake trim 100% ST Trim at center or neutral and TH trim at center or Nuetral. Also after trying to bind with AVC I I follow maual procedures full throttle, full reverse after full reverse light goes out on receiver but won't brighten while calibrating full left full right. Also the car will not hold center on the front tires.
Not sure if this is a servo issue or receiver issue. Also a possible remote issue.
