Rich8692
- Bensalem Pennsylvania
- Infraction
- Notorious
- Outcast 6s
So today I took my notorious to the skate park for the first time and really beat on it besides my ramps I have and use in the grass. Well I broke some things first off let me state I had hell of a good time and cant wait to improve my skills and go bigger haha well let's start with the truck it's a 2019 notorious running on 2 Dynamite 5000mah 50c 3s, Armorwerks servo mount, RPM front upper and lower arms, hot racing front hubs and bearings upgraded receiver with a futaba 3pv 304. 2nd set of backflips sanded and glued taped vents and revented on tread 2 holes @180° removed long stock front bumper and just using small inner piece 2nd set of diffs and housings from Jenny's running 100k200k100k heatsink on motor I'm sure im missing something
But any anyway on to what I broke first off stock bumper is ripped on lower holes and upper bolts are bent. Next is I broke the rear arm carrier as well as I've been having a problem with the front steering rod end keeps popping off of the ball and lastly I blew a rear lower shock cap off (but found it!) And kind of cracked a front bolt that holds the shock on.
I will include some pictures of what's wrong what I am trying to get at is what is recommended for fix these problems, replace what needs to be with what's more suitable for bashing and any other tips I would really appreciate it thank you in advance.
