carckton driver
- Kraton 6s
im trying to charge my battery, 7400 mAh 4 cell, and its not charging at the amps i selected. i have a 12 volt 10 amp power supply hooked up to my hitec x4 x4 multi charger. the charger specs stats 200 watts output power with each bay/channel having 50 watts. when i hook up my 7400mAh 4s battery and try to charge it at 6 amps, the highest the charger will go, it only charges at around 3.5-4 volts. i find figuring out what power the charger is using vs what is being supplied very confusing since not everything is in the same units and i don't know electrical very well at all. why isnt my charger charging at anything over about 4 amps? i have tried using all the online calculators for calculating watt, amps and volts i can find but usually just to use one calculator i have to first use another calculator or even 2 just to get the info the first calculator needs and even then im not sure if thats in the input side or output side or if i have gotten numbers mixed up between the 2 and i cant make sense of any of it. thanks for any help in advance
