Bec mounting help
Uncle_buck
Toronto, ontario
  1. Notorious
So I'm installing a castle 2.0 bec in my notorious and for the life of me cant seem to find a spot to mount it. If anyone has some pictures or ideas as to where I can mount it i would greatly appreciate it
Do you have enough space right there?
Or maybe here?
Those were the spots I was looking at but the pos and neg on the bec arent that long I would have to really shorten up the leads of the esc @Peeeenuuutt
I found this pic online a while back. Gave me an idea for when I do get a BEC.
That wont work on the notorious there is the servo right there
Do I have to wire the bec right at the top by the connector or can I splice it further down the wire @Peeeenuuutt
I made an extra mounting spot from some old rubber:
You can splice it further down the wire, solder 'm on and tape it (or something).
A second possibility is to make a wire with a (i.e. xt60) connector from the main connector and solder the other connector to the BEC.
I killed so many BECs on my E Revo that I ended up soldering a JST plug to the esc wires, and soldering a jst plug into my BEC, and then just plugging it in. When it died, I sent it to castle, got a new one, put a jst on, plugged it in, rinse repeat.
It’s super nice because if you can fit in a small 2s lipo into your truck, put a jst lead onto it and run your BEC solely off of that battery.
Not a lot of "open" space on the outcast/notorious for things to fit nicely though.
Glad I'm content with 6V. lol!
