LittleFlowRider
I don’t know how I didn’t break anything or bend the mount but I took the plate out and it was strait as if it was brand newTf how did your survive its just impossible lol
Maybe he is already bend you did not know
Im mad lolI don’t know how I didn’t break anything or bend the mount but I took the plate out and it was strait as if it was brand new
Could you post the stl on thingiverse or something?It fits! Had to cut out little notches for the screws on the motor can end. I forgot to model for them. ??
This is the screw hole I used to hold the mount in place.
Wont fit im sure:cIt fits! Had to cut out little notches for the screws on the motor can end. I forgot to model for them. ??
Are you looking at the bearing holder? It can be moved with 1 screwWont fit im sure:c
Will need to modifie it
I wont remove it and mine is broken into 2 pieces i just clued it backAre you looking at the bearing holder? It can be moved with 1 screw
Ah gotchaI wont remove it and mine is broken into 2 pieces i just clued it back
