Premium members don't see ads. Click here to upgrade.
Big Bore Aluminum Shocks
Cowbell
Active Military
Senton
Hey guys,
Picked up a set of big bore aluminum shocks off eBay a week or so ago for my Senton 3s. Filled them with 50wt and slapped them on. I’ve noticed that adjusting the spring height all the way up helps with cornering however, hinders ride height. Guess its something that just needs adjustment until I find what I like. My question is, do these need a “bladder”? I’ve watched a few YouTube videos on rc suspension and I’m seeing people having bladders in their suspension. Not very knowledgeable with suspension which is why I’m reaching out.
Thanks in advance
Mr.Duke
Likes to blow things up
NC
, Talion, Notorious
I think if you tried to insert a bladder on those it would rupture due to its design.
Note that if you take the shock cap off, the top of the shockrod makes a decent amount of contact in the center of the cap when it bottoms out.
Cowbell
Active Military
Senton
Ah, ic. So would that mean that it’s an “emulsion” type of shock? Fill them, bleed them, top off, and screw on cap?
Mr.Duke
NC
, Talion, Notorious
If these are the same shocks I'm thinking of they don't have a bleeder hole in the cap. You have to fill them and turn it upside down and bleed air from the bottom cap where the shock rod passes through.
If the shocks perform well with minor adjustment I'd run them just like they are
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast 6s, Typhon 3s
Cowbell
Active Military
Senton
I’ll have to try that out. Thank you guys for the feedback
That 1 arrma fanboy RC Build Logs 0
C Arrma 4x4 6
C Arrma 4x4 13
Bobster560 Suspension 12
Similar threads
