parcou
Hospitality Award
Rig of the Month Winner
- Location
- Eads, TN (outside of Memphis, TN)
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Well, the Typhon 6S is way heavier than the big rock.
Yeah I'm a little confused about the comment, I would have put money on the 6s Typhon being heavier than the big rock. I have both and the big rock had very soft springs compared to the 6s Typhon?
Sorry fellas I don't mean to confuse anyone...my bad...
Yes. I am referring to the Typhon 6S shocks, not the other Typhon shocks (3S I think) which do look like the Big Rock and Granite shocks. I'm referring to the red anodized aluminum shocks for the Typhon 6S.
Now, so many people want better shocks on the Big Rock/Granite I really don't see anyone talking bout how heavy a shock is. Personally, I have no idea what the 6S shock weights compared to the Big Rock OEM shocks. We all were going for better performance which the 6S achieve by the demand and sale of them. So how heavy they are in this rig seems small toome...man you see Rich Duperdash with beefy shocks so power can overcome that small one to forget about the physical weight of the shocks.
Yes, the 6S are bigger but they are "softer" in spring tension when you compare the data to the Big Rock factory springs. We up the springs to get closer to the spring in/lb of the factory Big Rock springs. Yes, you want better shocks like the 6S but you do not want to lose the in/lb that the Big Rock gave you by going down in in/lb for bashing. You want the springs to be equal or better:
Granite\Big Rock BLX Springs (Stock)
Front - 70mm @ 5.71 lb/in (ARA330538)
Rear - 80mm @ 4.80 lb/in (ARA330539)
Typhon Springs (Stock)
- Front - 70mm @ 85 g/mm or 4.75 lb/in (ARA330237)
- Piston - 4x57mm (ARA330477)
- Rear - 84mm @ 56.6 g/mm or 3.19 lb/in (ARA330239)
- Piston - 4x64.5mm (ARA330479)
So you can see the numbers. Typhons 6S shocks if left as is you lose some spring resistance which is what you DO NOT want on the Big Rock for jumping that is. So we sometimes get the springs off the Kraton, Mojave, etc, and replace the softer Typhon 6S springs with those. In my case I used Team Associate on my Typhon 6S shocks that are on my Big Rock:
Team Associates Springs for Typhon (Black)
- Front Yellow (ASC81215)
- 5.4 lb/in
- 70mm
- Rear Yellow (ASC81220)
- 4.6 ib/in
- 79mm
I apologize for the confusion I hope with the data this cleared that up. I'm not looking at the physical weight I care less about that people like Rich are not worried about a shock being physically heavy. We want performance
