It’s probably stuck inside of the hub plate.I don't see the small spring that puts tension on the clutch. Maybe that's the issue?
On my 3s I did have the problem after some use and had to set it tighter than the manual tells you to.
Here is diagram with spring. It goes on the long screw.
Yeah definitely get that rebuild kit with the plastic nut insert. Makes a world of difference.My best advice is to rebuild the whole thing with new pads and use the new slipper mant.kit with the plastic nut insert not the plastic nut with metal insert. It’s the same set up on the new v3 cars , I’ve been using this set up on my outcast and mine does not give me any troubles. Here’s the part number ARA311033
